I have 8800GT on an Asus P5K. I would like to setup 3 monitors... help
25 Apr 2007
London
Hello all
I'll have x2 Dell h2311 and I also have a 42" LG TV.
With 8800GT, I can run 2 monitors at the same time, I would like to plug the Dell 2311 on the x2 DVI of the 8800GT and I would like to run a clear 1080 resolution on the 42" and all three displays to be on simultaneously.
How can I go about doing that? Are the a HDMI cards or do I need a second graphic card?
Thanks
You can only drive 2 displays at a time from an 8800GT, there are external adapters you can get if you wish to clone one of those displays, if you want 3 different desktops then you will need another GPU in there too or an ATI card that supports eyefinity with a DP adaptor for the 3rd display (not a configuration I reccomend personally).
Thanks. Yes, I would like a 3 desktops to run at the same time.
