I bought myself a GTX 1080 and discovered on receipt that it was far to wide for the case I was using, the Carbide 240. It was too big by a good inch which did not include the cables which would also added to the height when fitted.
So I bought a Xmigtech Aquilla and I hate this case. It is so poorly designed, there is little space for the cables from the PSU because the 3.5 HDD carrier is badly situated it could easily have been moved 30mm further forward. In fact you really struggle to get the SST-ST60F-P in to the case once the cables are fitted and it is going to be so interesting if I need to remove it. It says and is supplied with a rear fan but this blocks the installation of the motherboard.
So I have been trying to come to a solution.
Do I return the card, can I now as I have had it installed and running for two days?
Do I look for another case, needs to be M-ATX, coloured, windowed?
Do I look for a small PSU? But to be honest as I really dislike this case this is the least favourable option.
Do I see if I can swap my 1080 for say a Evga here which I note is only 111.15mm which should fit in the carbide?
