I have a Problem with network connections
18 Oct 2002
Sunny Cheshire
I recently gave a friend of mine my old computer,I built the system about 4 years ago and it always worked fine but recently she has been having problems with her net connection, for some reason it will drop the connection I have tied to troubleshoot the problem the error windows 7 gives is
"Local Area Connection doesn't have a valid IP configuration"
I have googled this and it would seem that it is not an uncommon problem but I am yet to find a reolution I was wondering if anyone here had ever had this and managed to find a fix. I have reinstalled windows 7 64bit but the problem persists the lights on the router are always solid she is with BT internet adsl
Thanks
Thanks for the replies,it is a new model home hub I'm not familiar with this router she is using the onboard net controller I never in all the years I used this PC had the problem she has I was thinking of connecting my laptop up to the hub and seeing if I could replicate the issue, if I type ipconfig from a command prompt to get ip network details I will manually insert them to see if that helps.
