I have intergrated and dedicated GPUs??
28 Jan 2011
Hey guys,
i have just finished my build, but i have noticed that in afterburner is is registering both GPUs???? Even though there in no DP cable in the motherboard??
do i disable the intergrated GPU or leave it alone????
thanks.
Yeah, they're still active if you don't disable it. If you plug the DP into the motherboard on Ryzen 7000/9000 CPUs, you can actually play on your graphics card through the motherboard :D
I'd disable it anyway, IGPU don't have their own memory so windows will likely be reserving some GBs for it
Task manager > Performance > memory.
shows on there hardware reserved at the bottom right
My cpu seemed to be running slightly higher in usage to unit I disabled it. Not my much though.
