I have new Bios, Please help me with setting for my OC i73970x
6 Aug 2013
Hello
Many months ago you helped me over clock my cpu by giving me some setting to use and they worked great and Iv used them ever since , I just had my motherboard replaced asnit was fauly , and now i have the newest bios and I see their are more options to chose from than before , I now have version 4701 asus rampage iv extreme.
here are the setting you gave me before
" For 4.8 with 2400mhz RAM. Try the following, remembering each CPU is different.
48 Multi by all cores
Vcore 1.4v
VCCSA 1.195
VTT 1.15
DRAM voltage 1.65v
PLL 1.65
LLC High
For RAM set XMP and Rampage Mode 1
Now test. Vcore may need to go up depending on the CPU."
please can you advice me what needs to be changed ? (if anything )
Thanks loads
Sleepyluke
cool , so I set it all up as before , or as close as i could get it.
One thing I noticed is I have CPU LLC and a VCCSA LLC ???
Which of these should I be adjusting ? ( as above it only reefers to LLC ) ??
and now the CPU LLC as 2 extra option "ultra high " and "extreme"
.... so go's ,auto,reg,high,ultra high,extreme
The VCCSA LLC only has ,auto,reg,high,extreme
update....
Im also getting freezing and overclocking error always after my pc has been sleeping and then been woken up ? will uping my Vcore fix this ?
Thanks for any advice
