I have newtoyitis and my knowledge is out of date
Man of Honour
5 Dec 2003
Just to the left of my PC
I want a new toy and the only piece of kit I can reasonably upgrade in a way that I would notice without spending silly money is my monitor...so that's my target for a new toy.
The problem is that what I know about monitors is out of date, so I'm going to ask for advice on here.
My current monitor is a Samsung SyncMaster B2430. 24 inch, 1920x1080, 60Hz. Nice quality and still perfectly functional, but a bit dated now.
Graphics card is a 1070 Ti with superb cooling that boosts to silly levels. At stock volts, it's limited only by power draw and if I feed it max power it outperforms a 1080. I run it at stock, but I did overclock it just for benchmarking as a "How high can you go?" thing. CPU is an i7-4790K, so between the two I think I can go a bit higher than 1920x1080. 2560x1440 looks like the best bet for me.
Size-wise, I think ~28 inches would be the best size. I think more than that would probably be too big and less than that would probably not be quite the upgrade I want.
G-Sync would be nice, but I'm not convinced it's worth the extra ~£200 it costs.
I don't know how much difference refresh rate makes, so I can't make a good decision on that. TN? IPS?
I want no dead pixels. If I have to pay extra for a monitor that works properly, i.e. all the pixels work, so be it.
My sensible budget limit is ~£300 because this is just a toy I don't really need, but that's not set in stone either way. I'm tempted by that remarkably cheap AOC monitor that's selling like hot cakes (£200 for a 32 inch 2560x1440 monitor!), especially after reading reviews of it that say it's surprisingly good and far better than the price implies, but the size puts me off.
Refresh depends a lot on the games you play though I still find 100+Hz smoother on the desktop as well - but if you mostly play slower paced games, etc. it isn't as big a deal if you play twitch shooters, etc. you will likely really notice the benefits of a high refresh monitor.
If you shop around there are currently offers for G-Sync monitors down around £150 compared to the typical prices they've held through a lot of 2017/18 making the G-Sync "tax" more like £50.
If dead pixels is a big deal then IMO Dell is the only best option really other than going for professional brands which tend to have decent pixel guarantees.
I'm gaming on a 4820K with a 1070 at 1440p so your setup certainly should be OK for now.
