I keep having to reboot my primary Linksys Velop mesh unit
Caporegime
13 May 2003
Warwickshire
Hi all
I've had a Linksys Velop mesh system with 3 nodes for about a year, using TalkTalk FTTP 500.
I'm generally very happy with it, but I sporadically (about once per week) have to reboot the parent node because it drops internet connectivity.
In my previous house using a Virgin Media router, I almost never had to do this, so something is wrong.
A key point is that I've ditched the TalkTalk provided Eero and connected the Linksys node straight into the fibre box. I did this just to simplify the network and remove unnecessary (?) components.
I suspect that my issue stems from this somehow, although from everything I've read about most mesh systems, this should work fine as they can be modems and mesh nodes both.
Does anyone have any ideas what might be causing this? Could it be something to do with when my ISP refreshes my IP address?
Many thanks.
I'm assuming this will be the same as most fibre setups.
Have you cloned the mac addy of the eero / informed your ISP of the new mac addy connecting their wan?
With it being the weekend, it might be quicker to do the clone thing.
Get the wan mac address of the eero kit, put it in the mac cloning bit of the wan section of the velop.
Narrow down what the problem is - have you tried rebooting just the ONT when the connection dies? How about unplugging the WAN cable and connecting it again?
I've tried neither of those so far but will do the next time.
When the problem happens there's a red light on the Velop unit connected to the OST (indicating that it has lost internet connectivity), but the OST still indicates internet connectivity, so I've never gone beyond the Velop being the problem.
I might try contacting their technical support, but I assume they'll just point to TalkTalk being at fault.
Could be something as simple as the link between the ONT and the Velop
If it was a bad connection I guess power cycling it wouldn't fix it?
Maybe I'll try swapping the cables over between the two ethernet ports on the parent node.
It's peeing me off so much I'm actually considering getting rid of it and spooging on a Netgear setup.
Have you contacted the manufacturer and opened a support ticket?
"I might try contacting their technical support, but I assume they'll just point to TalkTalk being at fault."
I also had a terrible experience with them the first time I contacted their technical support. It was a total waste of time and they were useless, so I'm reluctant to bother again but I suppose I can't lose too much.
Well it happened again this morning and this time I did the troubleshooting advice in this thread, specifically starting with unplugging the black cable between the ONT and the Velop (acting as a router) in this picture:
This time, the internet re-established without needing to reboot anything.
What could be causing this? My first thought was bad cable, so I've immediately swapped it out for a new one to see if if happens again.
Many thanks for the help and ideas, also @ChrisD. I never thought unplugging an ethernet cable it and plugging it back again would achieve anything!
Edit: I guess if it happens again it could be a fault ONT and I'd need to go back to TalkTalk? Unless the Velop is somehow at fault and loses connection with the ONT until reconnected?
Next step, though slightly tedious, would be to put a small unmanaged switch in the middle, so you go [ONT] --- cable --- [Switch] --- cable --- [Velop]
By only unplugging one cable this lets you see which device dropping the physical link on restores the service.
Good shout, I already have a basic switch next to the Velop so will send the ONT connection through the switch if it happens again and see if that sorts it. Thanks.
If resetting the interface on the ONT brings things back up then I'd push for an ONT replacement
Not a single recurrence so far. It has been rock solid.
It looks like a simple cable swap / reconnect has solved the issue.
It really didn't cross my mind that it could be the cable as they're normally very reliable indeed.
Great that it was (seemingly) a cheap and simple fix though.
