added it to the registry in the right place. but it doesnt seem to work, mabye because i dont exactally know what to add to the registry or because i dont beleive the registry is even accessed until explorer.exe is running, therefore it wouldnt start it automatically.
When you boot up put the vista DVD in and boot from that, it should come up with the language selection screen, then the next screen should ask if you want to install, on the bottom left there is a text link that says repair installation.
