Any suggestions as to where i went wrong. This is what i bought and i just recieved 6x120mm coolermaster rgb fans daisy chained 3 per fan header auxiliary rgb headers. Not a complete newbie but its been at least 10 years since my last build.
Windows 10 home
Corsair RM650, RM Series, 80 Plus Gold Certified, 650 W Fully Modular ATX Power Supply - Black
Fractal Design Meshify C - Compact Computer Case - High Performance
Gigabyte Z590 VISION G ATX Motherboard for Intel LGA 1200 CPUs
Samsung 980 pro 1 TB PCIe NVMe M.2 (2280) Internal Solid State Drive
Noctua NH-D15S chromax.black, Premium Dual-Tower CPU Cooler with NF-A15 PWM 140mm Fan (Black)
Crucial Ballistix BL2K8G32C16U4B 3200 MHz, DDR4, DRAM, Desktop Gaming Memory Kit, 32GB (8GB x4), CL16, Black
Intel Core i7-11700K (3.6 GHz, 16M Cache, up to 5.00 GHz)
Also iv tried overclocking the chip using intels overclocking software where it keeps rebooting and running tests but it always says insufficient cooling to overclock. Should i be using a watercooler instead.
However gigabyte oc tuner will clock it to 8 cores at 5.2ghz
And yes there's no GPU i couldnt afford one right now im using the graphics onboard the CPU and motherboard. Not gaming using for CAD but not tried software yet.
Windows 10 home
