- 27 Jul 2005
- The Orion Spur
fenderbass86 said:You got it from B-grade? How was it when it arrived? Anything missing?
Oh yeah, congrats on a wicked purchase!![]()
Gaz
Because if people knew what was wrong/missing it would put people off buying it. It's usually a bargain for what you get though.s96024 said:Why does it not say what is wrong/missing with the b-grade products?
Gibbo said:Hi there
Glad you got a good deal but can you tell me what the condition of the packaging was like? Seals broken etc. and would you say the product had been used?
You've been very lucky anyway because it would appear this product should never have ended up in B-Grade but in clearance at a much higher price.
Gibbo said:Hi there
lowrider007 said:The box had already been open'd before as I could see a secound set of sellotape on the box, but the cables that came with it where all sealed and the monitor did'nt even have a finger print on it, the only strange thing was that on the Ocuk site it said it was black and on the invoice also, but as you can see i've got a silver one, not that I'm bothered.
Gibbo said:Hi there
lowrider007 said:Thinking about widesceen ?, Don't think about it, just do it !!!
Well, this being my first widescreen tft I have to say that chooseing to go w/s was the one of the best upgrades i've done, now when I look back at my 19inch LG I chuckle and wonder how ever I coped in squareville, if your reading this pondering as to wether to make the change to w/s then don't ponder just do it you won't regret it,
most new games now support w/s resolutions and many old games can be modded to support w/s, help can be found here.
I was a little worried that the increase in resolution from 1280x1024 to 1680x1050 would slow my games down but I can honestly say that I haven't noticed any difference in fps at all, I think this is partially due to my gpu being slightly cpu limited and the higher res helped take up some of the slack, this is the case in many systems.
