I messed up my default browser, Need help
Zip
Zip
26 Jun 2005
Australia
Ok i installed firefox to see what its like and i acident clicked set as my default browser and i didnt want to do that.
Ive now uninstalled it and now my keyboard internet shortcut key doesnt open any browser.
How am i suposed to make Explorer my default browser again :(
Open IE
Click Tools - Programs (tab)
Then check the tick box for:
"Internet Explorer should check to see if it is the default browser"
Then re-start IE and it should prompt you that it ISNT the default browser!!
That should get you to where you want to be ;)
div0 said:
Open IE
Thanks :D
You have been very helpfull :)
