I need 3x fans but not sure what type ?
Yes that's correct. The 780T can fit 3x 120mm front fans.. I think it can only fit 2x 140mm fans?
I thought 3x 120mm would be better than just 2x 140mm?
Memory is working perfectly :)
Do you want 4 pin pwm fans which a more speed controllable or case fans.
Do you have rnough fan headers on your motherboard to control them or maybe get a fan splitter cable.
The arctic p12 120mm are good fans and are very reasonably priced although the nocuta fans are slightly quieter but those come in at around 4x the costs.
