I need a cooler that will fit!
26 Aug 2005
London
Hi guys,
I've got a E6600 and a CoolerMaster Praetorian case, which will allow me a CPU cooler under 150mm in height. The question is, what do you recommend? Am looking for something decent to cater for overclocking.
Cheers!
To be honest, I would have thought that most, if not all CPU coolers are under 150mm in height. As for recommendations, this is a very good cooler for the price, or if you want to spend a little more then you should consider this and this.
I need something that wont exceed 150mm in height.
The Thermalright Ultra-120 Extreme is (H160.5 mm) so that's a no go.
The Noctua NH-U12F / Tuniq Tower is 155 mm.
I'm in the same situation as you with my Silverstone TJ03 PC case :(
I ordered a Thermalright Ultra-120 and realised that it wouldn't fit in my case by measuring it :(
From looking around including the XtremeSystems forums, it seems that the EnzoTech Ultra-X cooler is the best alternative to the Thermalright (some results show that it even cools better). The height of the cooler is 118m which will certainly fit however there's no one selling this cooler in the UK :(
