I need a new case.
Caporegime
3 Jan 2006
Chadderton, Oldham
$loth said:
I'd get the antec out of those two if you like the look of it.
Whats it like? Is it loud? It looks like it would be a tight fit in that case and the IDE HDD's getting in the way slightly.
900's supposed to be good for cooling and fairly quiet. It is also a dust magnet however. If i were you i'd go for a Lian Li PC7 personally. Very classy looking and doesn't hoover much dust from what i've heard.
Plus you can get them with windowed side panels which looks shexy! ;)
gt
Looks too cramped, the IDE cables will be too messy for that case and the place the IDE connections are situated on this mobo I have.
I need a case thats got plenty of space and a side window, but my budget is around 60 quid.
I have 3 HDDs in my Antec 900 and a X1950pro, I wouldnt really consider it cramped, even if the gfx card was an inch longer I think you could still fit 6 HDDs in.
Noooo I mean the Lian Li PC7, the 900 has enough space.
