just got a single slot GTX460 and my 300w wont handle that and also only has the one 6pin power connector and this card needs 2... any recommendations for compatible psu's ?
If the SH67H7 Pro was around £235 I would probably have got one myself.
I ended up modding an old G2 case:
http://forums.overclockers.co.uk/showthread.php?t=18111519
not seen the SH67H7 Pro?
I meant the SH67H7:
http://www.shuttle.eu/products/mini-pc/sh67h7/overview/
IIRC,you might be able to transfer the fascia of your existing H7 onto the H3.
just got this from shuttle...
Dear James
Thanks for your support
The SH67H7 will be available in UK channel next month.
We will inform you where to buy ASAP
If it is around £230 to £240 I might be tempted!!
BTW,did you managed to find out if the new cases can use mini-ITX motherboards??
no not for sure, but my understanding is the 'J' series can for sure.
The Sh67H7 will be £400+ Although that was to include a 500W PSU as standard as I understand, but even so it will be well over £100 more than the H3
