I need a triple monitor mount
10 Jun 2017
ok so I have had enough of drilling my wall 200 times when I want to move my monitors haha.
I need a large mount that will clamp to my desk, it needs to be large enough to a 34" ultra wide, and two 24" monitors either side. The two 24s may be upgraded to 27 so preferably I would like it to hold a 34"ultra wide and two 27".
Is this possible, oh and the VESA's are 100mm each.
I had a similar problem, ended up buying single monitor arms separately. It's the best option really as it allows you to position your monitors exactly how you want them.
