basically since ive installed these via 4in1 drivers , my computer reboots with games , didnt used to reboot before
is there some program that will wipe them clean
Some versions of the 4in1 drivers were buggy, I would know because most of my computing has been on VIA (current rig & several other machines are also the same). So, you should download the latest drivers (here) & try them & see if any issues. If same problem, then I'm sure this ones would hav overwritten the others and inturn allow you to unistall them
What I don't get is how you managed to run propely without the drivers in the first place. I know Windows installs a default set of drivers, but I can't install any GFX, etc drivers until I install the VIA ones
