I need adsl, gigabit lan and wireless all in one, does it exist?
30 Nov 2005
Does it exist, if not, how can i do it??
i currently use a bt 2100 wireless 4 port router, could i simply plug a 4 port gigabit switch into this or is it not that simple?
Yep, you can just add a gigabit switch onto one of the port interfaces from your wireless / wired router.
Alternatively, Dlink has got a router out with WiFi and wired gigabit 4 port switch. Check in the routers section on the shop in ocuk.
It is that simple, obviously only devices on the switch will be able to connect at 1 gigabit though.
Excellent, that'll do, i'm sick of transferring downloaded files from my laptop to pc @10MB/sec lol!
just need a gigabit adapter for my vaio laptop, i got the only one without gigabit i think!!
