I need advice for a gaming monitor. Budget: 500 - 600 €
4 Nov 2019
Hi to all the members of this forum,
after several years of using an asus vw222u I decided to change monitors for personal reasons. I have a budget of 500 - 600 €. I have a gtx 1080 xtreme gaming video card and I would like to take full advantage of the card and the budget.
Requests:
Gaming monitor, IPS panel, 144 or 165 Hz G-Sync or G-Sync Compatible, Resolution 2560x1440, 8 Bit or 10 Bit, <1 ms of lag
Questions:
  1. Is there a noticeable difference in performance between a G-Sync and a G-Sync Compatible? This is what worries me most.
  2. Among the Asus TUF Gaming VG27AQ, LG 27GL850, which Aorus AD27QD can meet my needs? And if not, what other monitor do you recommend?
  3. I noticed that IPS panels have a poor contrast. Has this scarcity ever given you any problems?
  4. Models like the PG279Q or XB271HUbmiprz are interesting and are respectable but aren't obsolete by now? Or am I wrong?
  5. Or maybe it's better to aim for a top in full hd?
Since I want to make a right choice I'm waiting for more reviews on Aorus FI27Q-P and Viewsonic Elite XG270QG models.
Sorry for the long post but I think the rush to buy is a wrong move and therefore I ask for your advice.
I thank you in advance and look forward to your opinions.
Best regards,
hitmanboy47
