i need advice with my case!
5 Jun 2005
Southampton
OK so fitted my new gcard, running nice all week, i stick the shell back on and bam it sounds like a hoover and gcard temps getting near 100, you can feel the hot air all round, so needless to say im back without my case.
I thinking i need a hatch or window that close when not gaming and open when in the battle?
its almost touching though, im not sure it would do the trick, but saying that it wont hurt to try that, and then cut the window if that fails.
i would cut a window big enough so you cannot see the other holes then fit Black Mesh to keep the dust out
