i need advise on what to buy - new system
19 Aug 2005
Beds, UK
hi guys, ive been away a long time, but i need your help.
my current pc is getting VERY long in the tooth now:
athlon XP 2400
MSI 6340 mobo
1 gig PC133
ATI 9800XT
its slow i know, but its as stable as you like, it NEVER misses a beat, and has done me proud.
but, i'm after a new one, and will pretty much need everything, so i may as well start from scratch.
i will we building over christmas i think.
i hear the Core 2 duo chips are the way to go, but which one?
the problem is, i dont really know how to go about speccing one up, my budget is pretty flexible, or maybe you lot should read SMALL hehe, but ive had a few thoughts.
1. SLI compatible mobo might be worth investing in, so i can buy a second graphics card later on, when there cheaper.
2. i dont play many games at the mo, but a new pc would certainly help, i'm looking forward to the next installment of half-life. I'm playing the new FEAR, but the PC is struggling somewhat as i'm sure you'll appreciate!!!
3. i use a TFT, so the max res i can use is 1280x1024, so a top end card is not really required (or is it?) lots of eye candy might be nice tho.
4. is it worth going for 2 gigs of RAM now? or getting 1 gig then upgrading later?
5. i would like a mobo that will last me a while, so maybe i could upgrade the cpu at a later date.
6. for some reason i am swaying towards Nvidia rather than ATI, since a friend has had quite a few probs with his 9800Pro.
i keep speccing up a complete system with a case, raptor HD, BIG HD, 2 dvd drives, mobo, cpu, ram, etc, and prices seem to be about £1000 ish, i would like to spend less than that, but i dont really know what i NEED.
so where do i start guys?
Many Thanks
Andy
champ222 said:
{snip}i keep speccing up a complete system with a case, raptor HD, BIG HD, 2 dvd drives, mobo, cpu, ram, etc, and prices seem to be about £1000 ish, i would like to spend less than that, but i dont really know what i NEED{snip}
Here you go...
  • Seasonic S12 500W Silent ATX2.0 Power Supply £67.99
  • Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case (No PSU) £48.99
  • Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £84.99
  • Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail £127.99
  • NEC AD7170A 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM £18.50
  • Seagate Barracuda 7200.10 250GB ST3250620A ATA-100 16MB Cache - OEM £46.99
  • Sapphire ATI Radeon X1950 XT 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £159.99
  • GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) £129.99
  • Sub Total : £685.43
  • Shipping : £10.95
  • Vat : £121.87
  • Total : £818.25
thanks for the reply, i have a hiper type r 480w PSU, would that be ok to use?
also, i'm looking for a mobo that has 2 pci-expressx16 slots, for an upgrade later.
and also, would there be much performance gain if i went for faster ram?
thanks again
If your getting an X1950 card you won't get around to another one since you'll be looking for a DX10 card by that time and the next upgrade after that you might be doing a complete overhaul. Of course up to you but it was for me I wouldn't bother.
I'm running an athlon xp system at the moment, I have no intention of a full upgrade until directx9 is truely dead. I will however be ordering a 7600gt for my comp to tide me over until next year.
Maybe you should do the same and wait a few months for prices to drop.
Jonny
