I need an idiots guide on how to reformat PC
26 Dec 2005
Liverpool
Hi guys, I am wanting to begin a fresh with the PC as I do believe there are some corrupt files on the PC which are having an adverse effect on Itunes and music etc.
I believe I need to reinstall or reformat the PC for a fresh install but I am not a very technical person nor have a done anything like this before.
The PC is running Windows 7 Home Premium 64bit operating system. The discs I have are:
The Operating System disc
Roxio Backup Disc
Drivers & Utilities Disc
Microsoft Works 9
I need an idiots guide on how to do this as I completely have got no idea what to do or what order this discs need to be used in.
Any advice greatly appreciated.
Thanks in advance.
If you boot the os disk you can select customise install. You can format/partion from that then carry on with the install. U have the tools with simple interface. Once windows has booted you can use the drivers disk. This will give u a fully working os. Install the other software in any order.
Just a thankyou especially to Clade for advice. I have successfully reformatted the PC and it was actually quite an easy straightforward thing to do so thanks again.
Better off not using the driver disc, but downloading the newest drivers online :)
What make/model is your pc?
