I need an MP3 player - that will display the folders on the SD card...
3 Feb 2014
The thread title says it all, really. I have a couple of oldish Mercedes, which cannot stream via Bluetooth (and nor can I; I don't have music on my phone). The cheap 'n cheerful Chinese units work OK, but I haven't found one that can display the folders on the SD card I use to store my music so that I can choose which folder to play from next. Can anyone recommend such a player, which must have a 3.5mm headphone jack to connect to the car?
Android phone as above.
But battery life might be an issue?
Old Samsung android mp3 player.
Cowon used to do good battery and quality sound, J3 was phenomenal.
Sansa Clip Plus has SD and well regarded. But unsure on folder viewing.
A good tag editor might be worth using on your computer if you can't get one that does folder view and SD support.
Well if he's using it in the car he can just plug it in to the charger, so battery life isn't an issue.
