I need bigger TFT
Caporegime
17 Feb 2006
Cornwall
But not at any price ;) And I don't just mean $$$.
I want to move from my 20" Philips IPS to a bigger screen - but I don't want to sit further away from my screen, I simply want my screen to take up more of my field of vision.
As an additional restraining factor, I don't want to buy something that a GTX460 couldn't drive acceptably - with AA off (I don't care about jaggies at high rez).
Currently my screen is a 20" Philips IPS with a dot pitch of .258mm. I'd like to go to 26+ inches (24" absolute minimum).
At first I considered a 24" 1920x1080 (16:9), but with typical dot pitch values of .26mm, I soon realised I wouldn't be gaining any additional height (30px = nothing :p)
Then I had a look at 27" screens with the same rez, and saw they were using a dot-pitch of .311. Whilst I wouldn't mind a slightly bigger pixel pitch than I'm currently using, I'm worried about going higher than .28, which I've read is the biggest acceptable for close-in work, because after that the display starts looking blurred.
Of course with a 27" screen you have the choice of jumping up a rez (WQHD: 2560x1440). Sadly these screens are very expensive (£800-£1k) and are also probably beyond the power of a GTX460 to drive smoothly.
So something has to give. Seems no monitor exists which will fill more of my field of view, whilst remaining crisp for close-in viewing and not requiring an uber-card to drive.
But I can't stick with my 20". It just looks so small to me now :( I can see all my desk around it and it's driving me mad. I need a bigger screen, that's for sure.
Have you considered a 24" (16:10) screen 1920x1200 res
I use the HP LP2475w which is a fantastic screen but unfortunately OcUK no longer stock, they have the zr24w which is out of stock at and the ever venerable Dell U2410 though the price seems to of crept up on that one
