I Need Compatibility Help!!!
Permabanned
19 Nov 2008
Peterborough, England
HI, I hope to be buying a Shuttle XPC SP35P2 from OCuk I'll be buying a graphics card (BFG GeForce 9500 GT 1024MB DDR2 HDTV/DVI [PCI-Express])at the same time and I need to know if these are compatible? Thanks.
That shuttle has a PCI express port on it, and they sell them bundled with a 9600GT so I assume its all going to fit in the case.
Would be very odd if it didnt!
The RAM on the card is only used by the card and there are no possible issues with compatibility.
The only issues with compatibility for a graphics card are...
Size - Will it fit in the case? And as someone already said they fit.
Power - Will the PSU be able to power it? Yes.
Slot - You need a PCI-E slot. You have one
