I need help building my pc again
28 Feb 2007
I need help building my pc again when i first started looking to upgrading my pc I wasnt gona get a 8800GTS card but i think i will now plus i was looking at getting a Intel Core 2 Duo E6320 as well.I need a Mobo,cpu,memory,videocard, Psu and if any money left a case.My budget is £560 i know its not much but at the moment i cant put any more to it..
Thanks
ps could you also recomend a 19in monitor to get at a later date
You can do it for the budget but it is tight. The OcUK graphics card is on pre-order and I know nothing about monitors so I'll leave that to someone else. :)
Intel Core 2 Duo E6320 "LGA775 Conroe" 1.86GHz (1066FSB) - Retail £95.99
(£112.79) £95.99
(£112.79)
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard £74.99
(£88.11) £74.99
(£88.11)
Akasa AK-ZEN-01-BK Zen Black Case - No PSU £24.99
(£29.36) £24.99
(£29.36)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £59.99
(£70.49) £59.99
(£70.49)
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £149.99
(£176.24) £149.99
(£176.24)
OcUK 2GB (2x1GB) PC2-6400 800MHz DDR2 Dual Channel Kit £59.99
(£70.49) £59.99
(£70.49)
Sub Total : £465.94
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £9.95
Vat : £83.28
Total : £559.17
bonsc said:
The case is if only theres any money left so dont worry about that and the monitor am gona get at a later date
There is a case in the specification I posted because it all fits into the budget. If you can't wait for the graphics card to come into stock (check with OcUK directly when that might be) then drop the case and get a more expensive one, otherwise that specification should be fine. :)
Thanks m8
2gb memory is better by far, what component are you thinking about skimping on that you might only get 1gb instead of?
I want to get what really needed but am trying to mess around with my budget at first i was gona just get a X1950 Pro as i wasent sure if the dx10 cards were worth it yet but i got told they were am trying to fit the best in to my budget m8
