This might be a bit long but bear with me.
I have been running Set@Boinc pretty much since the beginning and have had very little problems up to now (apart from the problems on Borkleys end)
But yesterday I had a horrible time, at times Boinc made my system unresponsive and hung the whole system.
When it did work it meant that opening another program like Internet Explorer or Outlook took ~5 seconds when with Boinc off it loads almost instantly.
I have never had this with Boinc before.
Obviously this is unacceptable, so it got me thinking it might be my system that has become unstable so I ran Memtest86+ which ran fine for 45 minutes, then I ran Prime95’s Blend test for an hour without error so I’m stumped.
I run an optimised version of Seti@home and Boinc (unfortunately I can’t remember which one, I think I downloaded it from http://www.marisan.nl/seti/ ), could that give me the problems?
Or can a WU cause the unstability?
So what should I do now, stop the WU I’m crunching (how?), reset the project, go back to the default install or a different newer optimised version?
