I need help fitting v8 cooler to mobo
13 Jul 2006
Hell!! \m/
Hi and hello. I near killed CPU removing OEM as it stuck and rebent pins as getting on too hours Now its in I wanna add therm and cooler and that's it.
I have cm v8,what is needed and any help from pics?
on Friday turns into a crack den
But on my own and every Friday
Tony, this I can believe :D
I have looked at the pics and read your posts but neither shed much light on what the problem is, im guessing you are having trouble fitting the cooler but you will need to provide clearer written details and clearer pictures in order for us to help
What is it with you people and poor grammar. Be serious even online so anyway...
e4915cd9
Fyi I am not a crack head ... They don't chat about quads for hours then hit the gym. I do mostly smack complately diff the stims help me work... Im work we have oem xeon and all Intel but I took a poe switch we never needed man writing in python is a pain till,,.....
Daddy's here.....
How does it fit and are my parts all there for am3???
tony man, you need to get help seriously. i did a quick look around at where else you post, stopy with the drugs. stop with the drink (not sure that you do drink, but they usually go hand in hand) and take care of yourself. you are getting worse and worse.
if you are an elaborate troll however, posting on numerous sites under different personas to get your rocks off... well played sir... well played.
On topic ideally I will do a Tony lonely thread when bored n not working on this day rig. I want new cooler here installed but I got this from my mate he had on a LGA one so no box he gave some spare bits. I normally clip it but this I can't figure it took 30m rebuild then CPU ages And now this....
When I took the oem amd one off I took brackets off as photo for this v8
Ok sir i apologise for calling you a crack addict, i shall change it to smackhead instead, being unfamiliar with your particular brand of drug abuse it was a simple error.
