OK I've got my Q9550 up to 3.723MHz 100% (8 hours prime) stable.
My voltage however is at 1.4000v which I've been told is high and my absolute max temp at full load is 70degC.
I'm convinced I can get this chip to 3.8MHz or higher and hopefully drop the CPU core voltage a little, but lack the skills to take it from here!
I would very much apreciate any advice on what to try. My current clock is set up as follows:
CPU Core = 1.4000v (although max in CPU-Z under load is 1.330v)
DDR2 = 2.2v (voltage recomended for my ram by crucial)
CPU VTT = 1.16v
MCH = 1.37v
ICH = 1.12v
ICHIO = 1.60v
DDR2 Ref Voltage = 0%
CPU GTLREF 0&2 = 67%
CPU GTLREF 1&3 = 67%
RAM is set to 1:1.20 (1051MHz) 5,5,5,18 (2T) it's 1066MHz RAM.
Now I really don't understand many of those numbers (some I'll admit I just uped a bit randomly to try and get a few extra FSB).
EDIT: Oh and incase it helps my mobo is an Abit IP35Pro and cooler is a noctua with 2xP12 fans.
CPU VTT = 1.16v
MCH = 1.37v
ICH = 1.12v
ICHIO = 1.60v
