- 11 Nov 2007
I need help pls
i recently built a computer about 2 hours ago for the first time. i think everything is in where it should be so i turn it on and expect it to show on my hd tv yet it doesn't. it does not even make the beep noise like when you first start a computer, so i open it up and notice that there is no speaker wire coming from my cm690 case. i dont know whether there is one on my motherboard. i also have the all the right wires for my tv.
can anyone suggest how i fix this because i cant do the bios wthout it displaying on my tv.
my specs are
q6600
8800gts 512mb
2gb ram
p35c-ds3r gigabyte mobo
artic 7 fan
550w corsair psu
160gb hdd
20x lg dvd
and when i start it up all of the fans and ligts are going even the one on the gpu, just no display on a monitor or on my hdtv, i dont think my mb has an onboard speaker nor does my case.
edit:i just took the ram out and there was a slight beep, but still no signal
my specs are
q6600
8800gts 512mb
2gb ram
artic 7 fan
550w corsair psu
160gb hdd
20x lg dvd
