I need help re-overclocking!
20 Aug 2013
Hi, when i bought my PC me CPU was overclocked to 4.00GHz but yesterday i started messing about with the bios settings and i somehow disabled the oveclock and now im back at my stock clock which is 3.60GHz
My specs are:
CPU: AMD FX-4100 overclocked to 4.00GHz (But is now at 3.60GHz after i accidently disabled the OC)
GPU: Asus Amd 7750 1GB
Ram: 8GB DDR3 1333Mhz
HDD: 500GB Deskstar
(This runs windows and has all my games on it)
Motherboard MSI 760GM-P21 FX
OS:Windows 7 Ultimate 64bit
So can someone tell me how to overclock my CPU again, and if you think its possible, an even higher OC?
I looked for tutorials but no one has done one with the same motherboard as mine so all the BIOS is different
Thanks!
P.S. If you need pictures of my BIOS just ask and I will upload some and link you to them.
Thought that was a bit strange - my first Google for overclocking your particular CPU and motherboard came up with;
"I suggest you get an infared thermometer and check the temps of the VRMS under load. That mobo was not originally designed for the 95 watt cpu and is likely to smoke up the room if you aren't careful."
Perhaps that's why there are no guides?
