i need help with this build for a friend.
2 Jan 2005
West Midlands
Zalman T7 MID-TOWER ATX CASE - BLACK WINDOW
ASUS TUF Intel Z390-PLUS GAMING WiFi 9th Gen ATX Motherboard
Intel CORE I5-9600K
Cooler Master Hyper 212 RGB Black Edition Cooling System
Corsair Vegeance 16 GB (2 x 8 GB) DDR4 3200
Western Digital_Black SN750 1 TB NVMe Internal Gaming SSD - Generation 3 PCIe, M.2 2280
Seagate 2 TB BarraCuda 3.5 Inch
Sapphire Radeon RX 580 8 GB NITRO+ Video Card
be quiet 600 Watt System Power 9 CM Semi Modular Bronze ATX PSU/Power Supply
ASUS VP28UQG 28" 4K FREESYNC GAMING MONITOR
GameMax Click RGB Mechanical Feel Gaming Keyboard
Rosewill Jet RGM-300 Gaming Mouse
total cost is £1236
not sure about the GPU or 4K TN monitor
can someone spec me AMD equivalent or better intel cpu with around £1000?
thanks
MSI B450 tomahawk MAX & 3700X should be able to beat that without issue.
You really dont want to install £1k's worth of hardware into a £30 PC case. It will have the build quality of a baked bean tin. :p
Spend a bit more:
My basket at Overclockers UK:
Total: £76.09 (includes shipping: £11.10)​
Bit better SSD for the same money.
Total: £168.65 (includes shipping: £8.70)​
Rest of the Spec is OK.
