I need HELP
5 Aug 2013
stockton-on-tees
so right guy if i go with this build below can i still run this ram as normal with out over-clocking it or will it affect the system because im not quiet ready to over clock because i don't know much about it yet or will i have to buy a 1866MHz and go with that? barring in mind i will over clock it eventually after some extensive research. or and if i do overclock it will it be ok cause i carnt afford anything to break :)
and can someone tell me if this build is OK :D
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor **FREE SIMCITY PC GAME** (AD580KWOHJBOX) £99.95
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £68.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £65.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD £43.99
1 x Cooler Master K380 Midi Tower Black Windowed Case - Black (RC-K380-KWN1) £39.98
1 x Corsair Builder Series CX 430W V2 '80 Plus Bronze' Power Supply (CP-9020046-UK) £39.95
1 x Cooler Master Hyper 212 Evo CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £26.99
2 x Cooler Master 12cm Sickleflow Red LED System Case Fan - (CM-R4-L2R-20AR-R1) £5.78 (£11.56)
Total : £410.00 (includes shipping : £10.50).
The memory has xmp profile you can set it in the bios to run at most speeds under that e.g 2133 and so on if it cant run at full speed :)
