What the link for the USB wifi dongle?Should work fine with the cheaper motherboard.
Kindly remove the link please it's against the forum rules.
Yes.What the link for the USB wifi dongle?
Ok I will now but how come I have to? It’s only a linkYes.
It's in the forum rules , No link to competitors as the forum is owned by Overclockers.Ok I will now but how come I have to? It’s only a link
Oh right ok I will nowIt's in the forum rules , No link to competitors as the forum is owned by Overclockers.
@Tetras Also I'm going to need new RAM for the new motherboard aren't I, So what RAM do I need to look for what I know will fit please, Also will I need to buy some thermal paste for when I'm removing the CPU and installing it on the new Motherboard? So could you help me with these 2 last things and then I think I'm all done and ready to order them all. Thanks
I only have 8gb in my computer now so I wanted to get new 16gb RAMCan't you just use what memory you have?
Most coolers come with the paste pre-applied, or a tube?
My basket at OcUK:I only have 8gb in my computer now so I wanted to get new 16gb RAM
Would this RAM work with it fine? https://www.overclockers.co.uk/cors...00c18-3600mhz-dual-channel-kit-my-4d0-cs.htmlMy basket at OcUK:
- 1 x Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey (SKU: MY-0AK-TG) = £49.99
- 1 x Thermal Grizzly Aeronaut High Performance Thermal Paste - 1g (SKU: TH-023-TG) = £3.95
Total: £62.64 (includes delivery: £8.70)
It should work fine but not sure if you can control the Rgb via the motherboard, something you may want to look into.Would this RAM work with it fine? https://www.overclockers.co.uk/cors...00c18-3600mhz-dual-channel-kit-my-4d0-cs.html
Ok no worries I’m probably just going to get the RAM you suggested, theIt should work fine but not sure if you can control the Rgb via the motherboard, something you may want to look into.
Teamgroup make very good ram and should work fine with your stuff.Ok no worries I’m probably just going to get the RAM you suggested, the
Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey,
Is this brand any good as I’ve never heard of it before and do you reckon this would work all good with my stuff. Thanks
Ok great, and yeah will do thank you!Teamgroup make very good ram and should work fine with your stuff.
Good luck with your build and let's is know how it goes.
No I can’t do that now as I’ve already bought a new case and I’ve already got an pc with a GTX 1660 Super and a Intel I510400F so just need the other bits and then I have a hood build. ThanksTBH you'd be better off buying a pre-built machine to remove all the uncertainty of getting the parts and building yourself.
i’ve finished my build except one thing, i need a new CPU cooler because the old one didn’t fit on with the bracket and stuff so please may you help me find a good cheap cooler please that will fit with my board what i bought. thanksTeamgroup make very good ram and should work fine with your stuff.
This is good budget cooler and better than the stock cooler but it's depends on how much you want to spend.i’ve finished my build except one thing, i need a new CPU cooler because the old one didn’t fit on with the bracket and stuff so please may you help me find a good cheap cooler please that will fit with my board what i bought. thanks
