- 4 Aug 2015
Hi everyone. I need some help or advice.
I haven't built a system in a while and have slowly got most of the components together to build a new Ryzen system. Basic details are:
Ryzen 7 5800X3D Processor
Gigabyte X570S Aorus Elite AX Motherboard
I'm struggling with memory choice.
This is purely a gaming PC, no work or productivity use. Main use Microsoft Flight Sim 2020, other games, Elite Dangerous and a few other like it. Anyway I bought some memory, maybe a little hastily and I'm second guessing. So the memory I went for was 64GB (4 x 16GB) Kingston Fury Renegade 3600Mhz CL16, looks like they are dual rank (apparently that's important). I though load it up and and have done with it. So got some advice from another PC part site and basically advised to drop 64GB as games wont use it and the memory controller may struggle, it may also even struggle to fully use 32GB. Also the RAM doesn't appear on the "tested" parts list for the motherboard, although it should be fine. So I can send the memory back but now I'm not sure of the best RAM to get.
First problem. The motherboard has 4 slots. I keep seeing conflicting advice as to either using two sticks or 4 sticks. Next 16GB or 32GB, do I go 4 sticks to achieve either memory requirement or two sticks? Next 3600Mhz OK or should I be going 3200Mhz or even higher?
This has got so confusing so some advice would be much appreciated. Should I keep what I have already purchased or send back and get replacement memory.
Many thanks
Many thanks
4 stick sets are actually kind of rare nowadays, but they do exist.
