I need some help here. I keep on getting Kernel Power Error
10 Aug 2011
I upgraded some parts of my PC. I changed the motherboard and CPU. I used to have AMD 1090T. Sadly, it got burned out because dust clogged in the heatsink. Even though the CPU fan was spinning, but 1090T was not getting enough ventilation. It burned out late December 2012. So I sold my old ASUS M5A78L/USB3 motherboard. I later bought an AMD FX 8350 and ASUS M5A97 R2.0 motherboard as a replacement.
Now here comes the problem. When I was using my PC I keep on getting Kernel Power error in Windows 8, even when it’s not under full load, just random usage. I had total of 4 Kernel Power critical errors. They all seem to occur at random times.
So I switched to Windows 7 and ran Prime95 for 6 hours without any errors. I ran Intel Burn Test for 8 hours without any errors. Even when it’s not under heavy load, I never got Kernel Power error.
None of my PC components are over clocked. Everything is stock frequency.
My PC Spec;
CPU: AMd FX 8350 4GHZ
GPU: AMD 6870
RAM: 8GB Corsair Dual Channel
Motherboard: ASUS M5A97 R2.0
PSU: XFX 450W
Samsung 830 128GB SSD
500GB Western Digital HDD
My CPU temperature under full load is 67c
I have updated the BIOS
I have disabled Cool n’ quite.
I have disabled APM in BIOS.
What could be causing Kernel Power Error in Windows 8?
These are the most 2 important question I needs to be answered for me.
If my PC can run Prime95, Intel burn Test and Memtest for 6+ hours without any errors, in Windows 7, does this mean I don’t have a faulty motherboard, CPU or RAM?
Is the Kernel Power Error related to driver error?
If someone an answer those 2 questions, I can be calm for a while. I'm actually really fed up
I have added the Kernel Power error below.
First restart
Log Name: SystemSource: Microsoft-Windows-Kernel-Power
Date: 18/01/2013 14:03:30
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Dino-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>3</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2013-01-18T14:03:30.615896800Z" />
<EventRecordID>1572</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Dino-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">6</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">3221225684</Data>
</EventData>
</Event>
Secund restart
Date: 18/01/2013 01:01:31
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Dino-PC
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2013-01-18T01:01:31.491149500Z" />
<EventRecordID>1522</EventRecordID>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Third restart
Date: 17/01/2013 15:19:27
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Dino-PC
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2013-01-17T15:19:27.402354400Z" />
<EventRecordID>793</EventRecordID>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Forth restart
Date: 17/01/2013 14:10:59
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Dino-PC
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2013-01-17T14:10:59.982376100Z" />
<EventRecordID>189</EventRecordID>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
this will be of absolutely no use to you, as we have no hardware in common, but im currently on my third re-install of win8 after receiving the very same error at least a dozen times over the last week.
No overclock, great temps on gpu and cpu both idling in the high 20's to low 30's, prior to this the system had been stable and had no hardware changes.
on this last re install, i have only installed drivers from windows update and so far (nearly 24hr) i've not had the BSOD followed by the kernal power error.
