Yep, the exact same problem.
- install latest DirectX
- Cleaning your system helps the heatsink to easily desipate the heat.
With either GPU?
- see whether you have any jumpers set in the graphics card.
- last solution may be is to try with another graphics card or test with one Graphics card.
