I need some new memory heatsinks for my 8800GT
5 Oct 2009
Spalding, Lincs
Where can I buy them from? Or even the double sided sticky stuff? One of mine has fallen off and it's no longer sticky!
clean them up and use tiny bit of thermal paste (arctic silver or whatever) in the center and a tiny microdot of superglue in 2 corners of each ram chip works wonders better than akasa thermal pads.
If you don't wish to do that then just get akasa thermal pads http://www.overclockers.co.uk/showproduct.php?prodid=TH-001-AK&groupid=701&catid=1428&subcat=But I can assure you the superglue method is best I ran an accelero s1 for 2 years, it stands to reason that thermal adhesive will dry out in warm circulating air.
Don't worry tiny microdot of superglue in 2 corners of each chip doesn't do damage (no damage or issues to my 8800gt or 4850 total 3 years ish usage) and if you ever want them off slide a razorblade underneath.
Too late, I ordered some akasa thermal sticky stuff :P I'm not spending £10 on something for a card I paid £30 for :p
why didn't you just use glue like i said ah well you will when they fall off again
