I need your help with a "spec me an eyefinity 28"/34" solution :)
11 Feb 2008
Lancashire, UK
Hi Guys,
I need your help with a "spec me an eyefinity 28"/34" solution.
I am an avid flight simmer and gamer, I am planning a build on x99 with a 295x2.
My old system is running with 3 HPZR24W (24") displays in eyefinity which has served me really well over the past couple of years but im now looking for a slick replacement.
My aim is to have a simplistic look with the new style "super slim bezel" monitors.
My initial spec was for three DELL 2414H monitors because they seem to match perfectly with the slim bezel.
I then got thinking about 4K - I will wait until they drop in price given im after 3.
I have since seen many newer multi-res eyefinity setups utilizing one large display, with 2 slightly smaller on the sides. I really like the 34" (LG Flatron 34UM65-P 34) for Centre but I cannot find something to complement it on the sides.
I want the monitors to be the same make, model so the look of the stand is the same even though they might be different sizes. My final requirement is that they all use DisplayPort as I don’t want to mess about with active adapters, tried that in the past, all the hassle and issues that come with eyefinity are greatly reduced with DP.
For example, the Asus SonicMaster MX299Q 29" Ultra Widescreen & 2 Asus SonicMaster MX239H 23" would have been perfect!! only the 23" doesn’t have DP :(
Then, the news that FreeSync compatible monitors should start to make a show at the end of this month, at least demo versions, so should I wait for those?
Any thoughts, feedback greatly appreciated, I read all comments.
Thanks guys!
