I need your oil burning wisdom
17 Mar 2008
'sup.
In much need of some help:
I need the cheapest most convenient/sustainable way of commuting to London (from Lichfield, Staffs) so around 140ish miles. Twice a week.
I was considering trains. Turns out, public transport is unaffordable or realistic. So the idea is to commute down, park car (free parking sorted), and get the tube in.
I'm thinking oil burner, VW passats, etc spring to mind. I know the Mondeo is a forum favourite, but I've a bad experience with past Fords so would like to stay clear.
It's got to be cheap to maintain, cheap to run overall, I'm trying to look at the bigger picture, so things like, is it likely to sustain a constant 300 mile a week trips for year-on-end with minimum maintenance/cost... Things like that.
Budget, from the lowest to around 6/7k. Plan is to get this for the commute, and something fun for the weekend so this thing can literally be a brick on wheels. I don't care, as long as when I arrive, I'm safe, calm, and have all 10 fingers and 10 toes - I've seen what these French cars can do!
Would really appreciate your help ladies and gents. And if that's not enough of an incentive, well... erm. ****.
Cheers.
The obvious choice is the Mondeo, so lets get that one out of the way.
On to some cars you might consider since you don't want the Ford. The Mazda 6, Honda Accord and the Volkswagon Passat. Err that's about it really, anything else I might suggest is either more expensive to run or rubbish. The Ford, Mazda and Honda are the best 3 options I think. Oh there is the Skoda Octavia aswell, I forgot about that one initially.
