Mitch007 said:Are you happy with the performance?
If so go for an upgrade on cooler for the card... save some cash... but sound like your itching to spend some cash....more than that required for a fan/cooler upgrade!
Ender said:if all you play is css then just get a zalman for your card, it sort the noise out fine
Mitch007 said:Upgrade the cooler is my advice, there are lots of options just check out OCUK site and pick a low noise solution....
CSS is cool what ip you play on?
