I pad sync problem
28 Oct 2010
I’ve just got myself an ipad 2. I’ve got it running wirelessly on my virgin super hub and have no problems accessing the net.
The problem I’m having is syncing my ipod with itunes on my pc (win7). I’ve tried everything and I still can’t wirelessly sync them.
If you look at this clip (1mineut 22 second), the lad has options when he hits “library” for some odd reason I don’t have any options like that. I have turned off win7 firewall and have tried a ping test, which failed. Everything is upto date and all passwords are set.
Is there anyone that can help…………..
Not quite sure what you're trying to do here. Are you wanting to sync your iTunes wirelessly? Or stream your library to your iPad?
Wireless sync only works on iOS5.
If you're wanting to play your music, make sure Home Sharing is activated in iTunes, Im not sure where that option lives on the windows version but should be easy enough to find. That video is correct in what he is saying, so other than that I don't know what to suggest.
Sorry im trying to stream over to the ipad, like in the youtube clip
Itunes is all set up ready and so is the ipad. If you look at the clip again he has an options when he hit “library” on his ipad (1.22 into the clip) I don’t have that option on my ipad.
Im a nood at this mate, what is “ios5”
iOS5 is the next operating system for the pad/phone, currently in beta and not available for the 'general public' just yet, so don't worry about that.
I really can't see where you're going wrong here, if your iTunes is set up properly like you say, and home sharing is turned on, then you should be good to go. Virus checkers on PC have been known to cause problems with windows/itunes/iDevices but if your Pad connects to your network then you should be ok.
Just double check that you have your AppleID typed in correctly, thats about all I can suggest.
