I return to folding!
Nope nothings changed for a few months now, you don't even need to use the beta flag to get the core_17 GPU WU's :)
In v7, it is under the Configure button - Slots tab - Select the GPU slot - Click Edit - Extra slot options. Add a new option, Name is client-type, Value is advanced. Then add another one called next-unit-percentage and value of 100
