I still have webcam problems...
15 Nov 2008
Scotland / Blairgowrie
I cant seem to get ANY webcam to work.
I have 2 cheap chinease things i bought of ebay. Which work perfectly well for a few seconds
I also have a Microsoft LifeCam Cinema which does not work at all. It wil lshow on msn/skype, as soon as people connect to see, it freezes on the first frame. Tried all sorts of drivers, skype/msn versions.
with the cheap things i bought they tend to work for about 5 seconds. Sometimes W7 thinks they disconnect when there not. They dont have drivers, just plug and play.
Windows device manager sees them as
USB(2.0) USB Camera. SN9C201. No warnings or nothing.
can anyone recommend a fix?
Doesn't really fix the Skype/MSN things but does it work properly if you are just configuring the camera?
(Pretty sure there is a preview thingy in Windows Live Messenger).
