I THINK I MADE A MISTAKE D:
10 May 2012
I just purchased an Intel i5 2500k CPU, the Gigabyte Z77M-D3H motherboard and an ASUS GTX 680 DirectCU II TOP.
Do you think i made a mistake? Should i have bought the 3570k and made the most of the PCI-e 3.0 support or does it not make a huge difference?
I originally planned on overclocking the CPU to bout 4.7ghz(ish) and so i went with the Sandybridge because i heard the Ivybridge starts running really hot at that sort speed? Will the extra few ghz be more beneficial to FPS than the PCI-e 3.0 support?
I will be air cooling using a Hyper 212 Plus :)
Thanks dudes!
Sounds about right, current cards are not fully utilizing the new bandwidth made by pci-e 3.0 so the difference is negligible.
With that cooler though I would probably stick with 4.2Ghz ish, you could always buy a better cooler though.
Other than that looks like the perfect build. :)
Yeah, i had a quick look and it didn't seem to make much difference at all. I just wondered whether the extra few ghz out the CPU would be more beneficial?
No I dont think you have made a mistake. You wont notice the small difference of PCIE 3.0 with only one card and youve saved a good bit of money on the processor. If you can overclock to 4.5GHz + you will find it is plenty fast enough.
Cool, thanks :)
Yeah, this is my first build so i will only be pushing it slightly to start with. What CPU cooler would you recommend to push it that high? Preferably air :)
OCUK has the 2500k higher than the 3570k
I'd get the 3570k, they're identically priced almost.
Cool, thanks :)
No problems. :)
The best air cooler which performs and is near silent is this; *psssst you want this*
http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC&groupid=701&catid=57&subcat=1395
That would get you to 4.8Ghz-5Ghz if you're processor allows it.
But if you don't feel like spending so much on a cooler and don't mind missing a few mhz I would swap the one you're thinking of getting with this;
http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-GD&groupid=701&catid=57&subcat=1395
