I've built a system for my step daughter, the majority of main parts being something like 12 months old. The mobo is an ASRock K7S41GX and is fitted with 192mb of RAM. It's running WinXP Home so I need a bit more RAM.
The manual says it supports PC2700 (DDR333) / PC2100 (DDR266) / Max 2gb.
She doesn't need anywhere near the top of the range fastest stuff as all she does is Bebo, YouTube and MSN.
It seems OcUK don't do my memory any more. So...can I fit 256mb or 512mb and expect it to work without difficulties? Will it just run at a lower speed?
Cheers
DM
Cheers
DM
