I think it's time for a upgrade.....?
24 Nov 2006
Sadly it's time to rest up my old trusty E8400 and HD4870 rig :(
Intel Core 2 Duo E8400
Windows 7 Ultimate Edition 64-bit SP1 (Build 7601)
CPU Arch : 1 CPU - 2 Cores - 2 Threads
CPU PSN : Intel Core2 Duo CPU E8400 @ 3.00GHz
CPU EXT : MMX, SSE (1, 2, 3, 3S, 4.1), EM64T, VT-x
CPUID : 6.7.6 / Extended : 6.17
CPU Cache : L1 : 2 x 32 / 2 x 32 KB - L2 : 6144 KB
Core : Wolfdale (45 nm) / Stepping : C0
Freq : 4499.83 MHz (499.98 * 9)
MB Brand : Asus
MB Model : P5K Deluxe
NB : Intel P35/G33/G31 rev A2
SB : Intel 82801IR (ICH9R) rev 02
GPU Type : Radeon HD 4870 @990/1200
DirectX Version : 11.0
RAM : 8192 MB DDR2 Dual Channel
RAM Speed : 500 MHz (1:1) @ 5-5-5-18
Slot 1 : 2048MB (6400)
Slot 1 Manufacturer : Corsair
Slot 2 : 2048MB (6400)
Slot 2 Manufacturer : Corsair
Slot 3 : 2048MB (6400)
Slot 3 Manufacturer : Corsair
Slot 4 : 2048MB (6400)
Slot 4 Manufacturer : Corsair
all this runs on a homemade water chiller, which I will be using again on my upgrade so what I'm looking for is chip that's going to clock well and last me another 5 years. Looking to spend £600 ish on mobo/chip/ram. Graphics card will be Hd7950 clocked high as I can get it, also is it worth going for a 2011 board and having the option (maybe) 8 core later or even go the 8350 route?
Thanks for the replies, Psu is Enermax Galaxy 1000 and I agree quad channel would the best option this:
i7-3930k (£469.99)
Asus P9X79 (£199.99)
Patriot Intel Extreme Masters 16GB (4x4GB) (£109.99)
looks like what I will go with,will just need to put the build off for a month but I've waited this long a little longer won't hurt. Thanks for your help.
It may be time to replace the PSU too, this good ol' PSU calculator reckons you should take 30% off the capacity for 1+ years of use.
Enermax make fabulous products though so it's a tough one. I have a machine of similar age (E7200) also with an Enermax PSU and would probably replace it if it were me.
