Spec:
E6600
DFI Infinity 975x mobo
4gb Corsair Ram
ATI 3870
X-Fi Fatal1ty
Enermax Liberty 600W PSU
Took it apart to clean it out and fit a water cooling block to my northbridge. Everything seemed to go well but when I swicthed it back on the fans spin up, there's not video output, hard disk LED is permenantly on and there's no POST beep.
Tried a bios reset, unplugging and replacing the mobo power leads and removing some components but no luck.
Think the motherboard has probably had it but can't afford to replace it for ages.
Gonna take it apart tonight and build it up piece by piece on my desk to try and find out what's wrong with it.
Anybody had a simlar problem and what was the solution?
E6600
4gb Corsair Ram
ATI 3870
X-Fi Fatal1ty
