Hi all,
I’ve bought a few components from ocuk over the years and browsed the forums for all the user reviews – you seem to be a knowledgeable bunch so I’ve come here for some advice because I think my psu is knackered… I was playing L4D when my brother, for god knows what reason, turned my pc off from the plug. Since then when I turn my computer on it starts up for about a second then goes silent for ~2/3 secs, then boots up. It starts loading vista but when its about to get to the password screen my monitor flashes up a no signal screen and goes into standby mode – the pc still runs tho (fans & lights still on).
My PC specs (bought it Jan/08):
Q6600 2.4Ghz @ 3.4Ghz
Asus p5k-e
Sparkle 8800 GT 512mb overclocked
Western Digital SATA2 320Gb
OCZ reaper 4 Gb DDR2 memory
580w Hiper type M
X-FI xtreme gamer 7.1
Antec 900
All the fans work (including graphics card), the motherboard isn’t making any error beeps and the HD sounds normal.
I think the psu got damaged and now it can’t produce enough power to start the system – is it possible that any other components were damaged? I’ve only had the confidence (and parts) to change the memory and there don’t appear to be any problems on that front.
If its just the psu I might just get a new one and possibly throw in an HD4890 in with the order, ocuk have been tempting me with the 4870 for weeks and then they drop the 4890 prices like a week after release – kinda glad I waited.
If I do need a new psu what would be your advice bearing in mind I’ll be upgrading the graphics card as well.
Thanks for your help.
Asus p5k-e
580w Hiper type M
Antec 900
