Hi guys,
Well this evening I was listening to music, crunching on rosetta at home and running the GPU client, when I heard my music skipping quite a bit. I checked it out in both winamp and songbird and it happens with all tracks that I've played so far, and it happens every 3-4 seconds.
I know that my CPU was running quite hot last week before I noticed, and I switched off all my DC clients until I've figured out what the problem is. Is there anything I can do/ run to check to see what the problem might be?
Any advice would be appreciated,
Yeggs
UPDATE: Ok, I went back to basics. Reset my overclock and it seems to be playing fine. Evidently I didn't have enough voltage going into the CPU. Sorry, I panicked a bit there
What do you guys do in the summer with regards to your overclocks? I'm thinking of turning mine down to 3.4 and 1.45v in the bios, the overclock doesn't seem to hold without 1.475
Yeggs
